How can I keep my Verizon Unlimited Data Plan?
  • Start date Start date
A
AC Question
Line 1 - Galaxy Nexus UDP, upgrade available
Line 2 - iPhone 5, TDP, upgrade available
1) How do I upgrade Line 1 to an iPhone 6 Plus >> Understand a bit but need exact steps!!
2) After upgrade in step 2, what would happen to the upgrade of Line 1 (assuming that in the method suggested, the upgrade of Line 2 would be used)
3) It seems that the SIMs in both are different. What to do about it?
4) Whether I should do it in Store or on Verizon web site or on Phone and what precautions to undertake?
Thanks a Ton!
-- MS
Thanks a Ton!
-- MS
Welcome to Android Central. You might want to post your question in the Verizon carrier discussion. It is a very long thread, but you should find some valuable information and get some help with your question. Here is the link:
http://forums.androidcentral.com/showthread.php?t=227608
MightyExecutor
