How do I connect EVO to play thru my car's sound system?
I bought a car holder that holds the evi and charges it and has a built in fm transmitter.
Sent from my HTC EVO-4G using Tapatalk
As others have said, there are several ways you can do this.
1. Aux cable is probably the best way if your head unit has an aux input. This is basically just a cable with a headphone plug at both ends. You can get them anywhere that sells electronics for about 5 bucks or less.
2. Bluetooth is the cleanest way since it is wireless, but you need to have a head unit that supports A2DP.
3. Cassette adapter. Cheap and easy if your head unit has a cassette player. These have been around since the days when everyone had those portable CD players.
4. FM transmitter. These can be a little expensive for one that works halfway decent (around $50) but your only option if none of the above options will work for you.
I have the aux cable but when i connect it it only plays thru the EVO and not tnru my car speakers
Did you put your stereo on Aux? My car has one button that flips from CD/Radio and AUX.
You shouldn't be getting any sound out of the phone if you have the aux cable plugged in. Do you get the little headphone icon in your notification bar when it's plugged in?
Mine plays & sounds good over Bluetooth, cuts the music when call comes in & uses car speakers to hear the phone call.
No headset icon
It worked with my itouch
Using usb cable that camwe with thre phone. One end into phone other into the cars usb port
Am i missing a step, need to hit a certain setting or download an app?
You can't do that. We're not talking USB cable, we're talking the headphone jack. If your car stereo has an aux-in headphone jack, you want to use a cable and connect it that way. The only reason it worked with the iPod Touch is because they have special programming in the stereo for them.
Seems like HTC SCREWED UP BIG TIME AND SHOULD HAVE TAKEN A PAGE FROM APPLES PRODUCT
THIS is wAY TOO COMPLICATED IN ORDR TO LISTEN TO A FEW TUNES IN MY CAR
It's not even vaguely complicated. You just don't want to try the options given to you.
HTC didn't screw up at all. I'm sure they would love to make it work just like an iPod/iPhone but they can't because Apple has a patent on it.
It's not complicated at all. You just need to look at the options and see which one works for you.
Blame Apple/Your Car Stereo. It's a special iPod-only interface, there's no way HTC could do it even if they wanted to.
There are cars that have better integration, like Ford's SYNC system. But for car stereos that only have iPod support, well, guess what? They mean it.
Shawtiee
