- Jun 17, 2015
- 1
- 0
- 0
Hi I recently purchased an asus zenfone 2 and put my T-Mobile sim card in everything is working great except I cant send any pics or mms files what do I do someone please help believe it or not I frustrating
I think this may have been fixed in the stock messaging app. I sent a mms successfully via sim 1 while wifi was on.
Not fixed yet. Seems like sending mms is not a problem. It's receiving mms while connected to wifi is where there problem lies. Fix it Asus.
I found in the setting+more+cellular networks+access point names+ mms+mmsc make sure the whole address is lower case
Ok
(Three dots on top right) save
My apn setting were automatically downloaded. It worked for a week then stopped. After trying everything I found an uppercase W was in my mmsc address. I changed the "W" to lower case and saved it. It worked right away.
When using 3G or LTE (or LTE | 3G in Roaming) I see no data icon at all or does it even exist?
I disabled Wi-Fi and I have all the information (APN) correct for Slovenian ISP T-2 (SI Mobitel & T-2 provider are joined) and I cannot recieve or send any MMS and the internet is not working either. The SIM card is in SIM-1 slot.
I tried to make hangout, asus messaging, google messaging app as DEFAULT (I even restarted the phone multiple times) and MMS is still not working. What else could I try? Thank you for answer.
Information:
ASUS_Z00AD
Android 5.0
WW_2.20.40.97_20150917
I got zenfone 2, 4gb ram, 64gb version.
