How do I get notifications to make noise, and not vibrate when set to "sound"?
deputydog95
60
The whole notification end of this phone is more complicated than it needs to be...
So far, if I put it on vibrate and I don't have "vibrate" selected in the apps and emails, it doesn't do anything.
If I select vibrate in the apps and email and set it to "sound", it not only makes noise but also vibrates too.
Is there a way to have it make noise and not vibrate when set to sound? And conversely have it only vibrate when set to vibrate?
Here's my settings.
MrSmith317
Mr Fix-It
Mar 1, 2010
2,206
277
You can generically but per app, no. The sound/vibrate/mute profile will only effect the notification and ringer volume. However if you have gmail set to vibrate then it will vibrate no matter what.
deputydog95
60
The issue I'm having is that if I leave gmail setting vibrate unchecked and I set the phone to vibrate, nothing happens.
What am I doing wrong here? This seems like it should be pretty simple.
gafly
487
15
If an app has its own notification settings (tone, sound, vibration, notification light) it will follow them. If an app does not have its own notification settings it will follow the system notification settings.
Sent from my Galaxy Note II
deputydog95
60
So has anyone found a way to have the phone vibrate on a gmail notification when only set to vibrate? Versus it vibrating all the time whether set to sound or vibrate?
BlastTyrant
162
After looking at your settings, you clearly have vibration turned on. If you don't want your device to vibrate, turn off the vibration. I have my vibration settings turned off, and guess what? My phone doesn't vibrate...
Sent from my Transformer Pad TF700T using Tapatalk HD
deputydog95
60
The problem is. It either vibrates all the time, or doesn't vibrate at all. I don't want it to vibrate when the sound is on. Just when set to vibrate. Even the ifail has a simple switch that allows you switch all audible notifications to vibrate.
I don't understand why this phone can't do that..... Why would I want it to vibrate when the sound is on. So dumb.... This makes me miss my blackberry at times....
ctgolf
Not to get too far off topic, but I'm having a problem getting my standard Email (not Gmail) to notify me with either a vibration or a sound. Neither one of them work. And I've got all my settings in the email and in Settings set to vibrate and ring for all notifications (just to see if I can figure out whats wrong). Nothing is working. The more I read the more it seems this is a Jelly Bean issue...
BlastTyrant
162
Most custom ROMs have customizable toggle actions. The one I'm using does... I can toggle all notifications to sound only/vibrate only/sound + vibrate. One of the awesome things about Android... Infinite customizations. If you don't like something about your phone, or its operation, more than likely someone has already figured out a way for you to make it the way you want it. Rooting is the first step... Once your phone is rooted, you can do just about anything with it
Sent from my SGS2 Skyrocket w/ Tapatalk 2
BlastTyrant
162
I'm not having email issues at all w/ JB. But I'm not using Gmail or the native email app. I've deleted both, actually. AquaMail is awesome... Never gives me an ounce of trouble. And looks a lot better than Gmail, too LOL
goodweather2024
