how do i hook my lg volt to my tv or ps3 help pls
Ralph Brownjr
how do i hook my lg volt to my tv or ps3 i only have acces to wifi at my house not at my cabin and i would like to do this in both places
really have no clue what iam doing i downloaded a bunch of apps and still its npt working i have no idea on how to do this i have a reg flat screen and lgvolt and a ps3 i lost my job and my children have no tv this would help so much ty
Sorry about the job.
If Chromecast runs on the Volt (no guaranty, it's not on the list yet, but it's free, so it can't hurt to try), the Chromecast device will work. It does need wifi, but it only needs an internet connection the first time you set it up, so you can set it up at home, then buy a cheap router (try a hock shop) and use it at the cabin as well. You can find the device on sale for $25 all the time. If you buy it at a store like Best Buy, you can return it within about 15 days if it doesn't work for you.
Instructions (if you need them - it's a simple app to use) are at Chromecast mirroring.
Wvn if the app doesn't work, Chromecast supported apps is a list of apps that should cast to the device, so you should be able to watch movies, at least. (The Chromecast app mirrors the phone screen to the TV, so anything on the phone uses the TV as a monitor.)
If you put the phone in portrait mode, it's going to look funny on a TV screen. Other than that (and you can't turn the TV on its side to correct that), it's great if you want a large screen phone.
may brasil dont ingles
Enviado de meu SM-G355M usando Tapatalk
