R rockgodrules New member Jul 14, 2016 4 0 0 Jul 14, 2016 #1 I would like to root my Nexus 6, and really the only things I care about are my contacts, is there any way of keeping them, programs and or methods.
JBoen Active member May 28, 2014 27 0 1 Jul 14, 2016 #2 I think you should enable google contact sync on your gmail account.
VW Maverick Retired Ambassador Dec 3, 2010 5,285 164 63 Jul 14, 2016 #3 Correct. Your GMail account holds all your contacts and once you sign in on your device, it will sync it all up. Mav. Last edited: Jul 14, 2016
bleached Member Apr 10, 2012 23 0 0 Jul 15, 2016 #4 If you have to ask this question, maybe root isn't for you!?
E Ed Briggs Well-known member May 14, 2013 1,004 0 0 Jul 16, 2016 #5 You can also go into Messenger and go into the menu and select "export to file". It will create a file called contacts.vcf. Then just copy it to a pc or whatever. Then you can import it if you ever needed to.
