How do I keep my Samsung S7 on while on Wireless Charger?
  • Start date Start date
A
AC Question
How to keep Samsung S7 on while on Wireless Charger
I have a Samsung Galaxy S7 Edge and the Samsung Wireless Charger. I enabled the Stay Awake option in the Developer Options. However, when the phone is on the wireless charger (not connected to the cable but charging wirelessly), whether it is charging or not, it will enter the sleep mode and the screen would turn off. I want the screen to be kept on (at least during work hours...). Does anybody know of a solution or an app that can control the wake state better (without rooting my phone).
Thanks,
Re: How to keep Samsung S7 on while on Wireless Charger
Just out of curiosity, why do you want to keep your screen on all the time?
Macrodroid can do it with a press of a button
I use the wireless charger at work on my desk and I want to see if emails come, or if I listen to music I want to see what is playing.
Its a bit annoying that I have to open it continuously.
Thanks, it does work partially, because the Macros have an option for opening the screen when the charge is going on.
But, when the charge is completed (and that's pretty fast these days) the screen turns off. Is there a Macro action relating to the proximity to the wireless charger?
