How do I remove the battery level notice on my Droid Turbo lockscreen after the upgrade?
A
AC Question
how do remove battery level notice on droid turbo lockscreen after upgrade
When screen is black and locked, hit power key, and battery level banner appears giving number of hours left and percent on batter. never did before update. would like to remove.
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
Re: how do remove battery level notice on droid turbo lockscreen after upgrade
Go into system settings > display and see if there's anything in there with that setting. If there isn't, then there may not be a way to disable that particular feature.
Here's the Droid Turbo forums if you haven't already looked in there: Motorola Droid Turbo - Android Forums at AndroidCentral.com
roth4796
