A AC Question Mar 31, 2016 #1 How to reset cellular data usage for ZTE on android phones? Reset internet data usage
B. Diddy Senior Ambassador Moderator Mar 9, 2012 168,272 8,889 113 Mar 31, 2016 #2 Welcome to Android Central! Do you mean that you want to change the data usage reporting cycle? Go to Settings>Data Usage, make sure you're on Cellular, and tap the date range dropdown. Then select Change Cycle to adjust when the month ends.
