How do I solve the problem 'unfortunately sales tracker system has stopped'?
  • Start date Start date
A
AC Question
How to solve the problem 'unfortunately sales tracker system has stopped'
Please give me the answer
The techno n9 is known with this issue, I just installed Root xplorer naivagated to system/apps and deleted sales tracker system.apk and .odex and that was all.......it works
Welcome to Android Central! Try going to Settings>Apps, select Sales Tracker, and Disable it (assuming it was preinstalled).
I am using Gionee F9. I have this app, which is using my phone doing malicious activities like sending sms, send whatsapp messages. Unable to disable it. Disable button is disabled. What to do??
Welcome to Android Central! It is most likely a preinstalled system app. You could try doing a factory reset without restoring any prior backups, but if the app is still there, then it's likely something that Gionee preinstalled. You'd probably have to root the phone to get rid of it, but it's hard to say if that might affect any other part of the system.
amaka
