How do I sync SNotes from my Note 8 to my Note 10.1?
CSI Guy
575
4
How do I sync my SNotes from my Note 8 to my Note 10.1. I would like to have the same notes on both devices but have no idea how to sync them together.
You just have to sign in with your Samsung account on both the devices. All your notes are automatically synced.
Sent from my GT-N5110 using Tapatalk 4
It is strange but my Note 10.1 has a template called Note and the Note 8 has a template called Memo. So they dont sync because they are different. Is there a place on Samsung website to download more of these templates so that I can have the same ones on each tablet?
I use DropSync on both Note 8.0 and Note 2. This syncs my S Notes (and other selected items) to DropBox and keeps everything up-to-date and available across all devices.
This syncs all notes between the two - including ones where I use the Idea Note Template on the 8.0 which isn't available on the Note 2.
Also, I like the small squares of the Idea Note, so I created a blank note using this template on the 8.0 and saved at the top level of my S Notes folder. DropSync then automatically copied this to my Note 2, so now I can use this to create notes on my phone (open the blank note and do a Save As).
Hope this helps.
ruhidubey0188
