How do I turn ON low battery notification on Moto G5 Plus (Android 8.1)?
CocoBZ
7
I have a Moto G5 Plus, and when it reaches 15% battery I receive no alert message or sound, so I can miss it if I'm not using the phone, which lead to me finding the phone turned off on a number of occasions because of it. I found nothing in settings and I don't want to use a third party app.
Try resetting app preferences Settings > Apps > three dots > Reset app preferences > Reset apps.
Got this info from the Lenovo forum and seems to work
Try Battery Notifier BT from the play store. You'll be able to set limits with notifications.
Good luck
birdsong2000
