How fo I fix my v30 accessibility problem
  • Start date Start date
A
Android Central Question
unfortunately accessibility has stopped how fix this problem. Ihave updated last update not fixed. I have resetted factory reset not fixed
What Accessibility feature is not working?
Can you access Accessibility at all?
Are you using any apps that aid or have Accessibility functions?
When you factory reset are you choosing the restore option for apps? If an app is the cause starting your device in Safe Mode should reveal if it is a device problem or a bad app. If it is a bad app everything will work as it should until that app is opened. This should show you how to do this;
https://www.google.com/url?sa=t&rct...=bOUrpxw5HtQ&usg=AOvVaw2CDGomFDWT2u-LuOL6lyCC
Become a member to reply in this thread. Having a two way conversation makes getting help easier.
KidColoringPage
