How hot is a safe temp for the battery?
evilhugbear
81
Hey guys,
I noticed in the wireless tether app, it shows the battery temperature. How hot is too hot for tethering? 45C? 50C?
Thanks! :D
I really try not to go over 104 f which if my math is any good would be 40 c. Don't know if you can safely run higher but I try not to.
From Nexus with love
I'm not too sure about a safe temperature. Anything over 100 seems bad to me. My nexus s 4g stays at around 36 degrees Celsius
Yes that sound about right... I've had my battery heat up pretty hot at times then return to normal with no damage. Certain things we do at times cause a phone to really heat up. Also phones normally have a built in protection that once they get to a certain temp they will shut down to protect themselves.
Michael4444
