With light flow it will produce whatever color you want
Tapatalk'd from my Galaxy S3
Is Light Flow working for you? Their web site says it has problems with the S3. One guy said he had to factory reset to correct them.
...Sent from my Prime Infinity
aparently the GSM s3 is supported but not the LTE ones yetIs Light Flow working for you? Their web site says it has problems with the S3. One guy said he had to factory reset to correct them.
Light flow works for the lte s3, I had it but un installed it because it was murdering my battery
Lightflow does NOT work on US version S3's. The dev is currently working on a fix but at the moment, it does not display the correct colors when in use.
Guess mine was a fluke. Because light flow 110% worked for me
Hiya rwbarnes67! I'm curious -- I based my claim mainly on the fact that both have a 'menu' button where options are hidden. What other similiarities do you see?
