M mclasser Well-known member Sep 30, 2011 121 2 0 Jul 1, 2014 #1 I lose about 1% every hour or two. This is with location services off and full WiFi & cell signal strength. Sent from my Note 10.1 via Android Central App
LeoRex Retired Moderator Nov 21, 2012 6,223 0 0 Jul 1, 2014 #2 That sounds about right.... GLS is probably the biggest wakelock hog... if he's put to rest, you'll probably see 0.8/0.9 an hour.
J JeffDenver Banned May 3, 2010 2,996 27 0 Jul 1, 2014 #3 mclasser said: How much battery does your N5 use in standby? Click to expand... Virtually zero. With the screen off I lose almost no battery. and I have everything turned on all the time except bluetooth (GPS, LTE, ect) If you are losing battery I'd look at your apps. Something is active in the background. Last edited: Jul 1, 2014
M mclasser Well-known member Sep 30, 2011 121 2 0 Jul 2, 2014 #4 ^Something is active alright- Play Services. Sent from my Note 10.1 via Android Central App
