How much can I expand my Memory by on the S7 Edge?
  • Start date Start date
technically you can put in up to 2TB (the limit of the sd card slot) but being that no card larger than 200GB exists at the moment, samsung listed 200GB as the max.
are you asking what is the max after you put in a card? Are you asking if you put in a 200g card if it is really 232g of memory? Or are you looking after you have inserted and formatted what the leftover is?
MightyExecutor
