- Jul 1, 2014
- 104
- 0
- 0
How much more is battery life shortened on High Performance Mode?(HPM)
Does it make a big difference on the drain if I enable HPM and ART?
You have an M8 and Nexuz 7?You would probably have to do your own controlled tests with both, everyone's usage is different.
Personally I find high performance mode to be unnecessary , the phone will use all its resources if it needs them. I guess the only usage would be gaming where you may not want the phone to be limiting resources
Posted by my Nexus 7 (2013)
Awesome!
Ok, I guess I'll leave it alone for now, thanks again.
Have you ever considered over clocking?
