How to associate camera to my microsd card and not device storage ?
herbeapuce
7
Hi. It seems my pictures are now saved onto the device storage. I would like to have then saved on my micro sd card , like It was before... How to go back please ? The camera app I'm using is the one that came with the phone it that matters. Thank you
stef
Look in the camera app's Settings for a place to change where it's storing photos. Change it there.
Hi and thanks for the help.
I tried that but It doesn't show a place to change for my sd card... I click on Settings - More Settings - Application Manager - Camera,
and then I have 6 new options : Storage, Data usage, Permissions, Notifications, Set as default, Battery, and 1 last option but unavailable and gray: Memory: no memory used in last 3 hours
if I click on Storage, all I see is " Clear data'" and " Clear cash" . I don't see a place to change for sd card...
what to do plz?
I also check Storage and my sd card in mounted , should be working... (3.6 used of 14.8 )GB
valldirtg
