AT&T Galaxy S8 How to change battery capacity info in Settings
xoominator
I had the battery in my Samsung 8+ replaced. The new battery is 3,850 mAh.
When I open Settings, scroll down to About Phone, and touch Battery information, it
displays the Battery capacity as 3,500 mAh, which was the capacity of the old battery.
Is there a way to update that? Or is it set at that permanently? If it's changeable, will
it actually effect anything, like charging time or time of battery usage?
Thanks.
The stock s8+ battery was 3500mah , you can't change that in settings
Iknownothin
