- Feb 12, 2014
- 159
- 0
- 0
I use a Pin Code to secure my phone.
Whenever I lock or unlock my phone, it makes a "click" sound. I want to change that sound to something else, but there doesn't appear to be any options to do that.
If I go to Settings -> Sounds and notifications -> Other Sounds, the only option is to Select or Deselect the "Screen lock sound". But there is no option to change what the sound actually is.
I can change the lock/unlock sound if I don't have any passcode enabled, but I can't find an option to change it while using a passcode.
Anyone have any ideas? I want my phone secured, but I also want to change that annoying click sound to something else.
Thanks.
Thanks.
