How to convert my Note Edge to S7 Edge UI
As far as I know, you will have to root the phone. I installed one of these ROMs on my Note Edge about a month ago and thought it was annoying so I went back to stock because It had a lot of bugs in it.
I have never found a custom ROM for the Note Edge that I really liked because all of them had some bugs in them or had some of the edge features disabled.
Thanks for your feedback. I also am not one for bugs so I will stick to the stock.
SM-N915F
You can just install an S7-type launcher. (You can't get an Edge display on a screen that doesn't have a curved display.)
