How to find where battery leaks??
Owen Kim
89
Mines a Sprint Variant and the battery usage stats on settings don't show much...
I do have certain syncs on for purposes, use smart watch, have a good number of applications installed, but the speed of this battery drain is insane and much faster than it should.
1. Press the menu button on your Android to start. Select "System settings."
2. Scroll down the systems screen. Select "Battery."
3. Look through the list of entries here. You can click on any of them to get more information. Each entry has a percentage listed next to it. This will tell you how much of the total battery is being used by that particular application.
4. Click on "Screen" to get info on how your screen energy is being used. You'll get info on how long the screen has been on. There is also an option here for adjusting display settings.
5. Click on "Display" and then look at some of the adjustable settings in the Display screen. Click "Sleep" to adjust how quickly the screen turns off from idleness, or "Brightness" to adjust how bright the screen is.
6. Say "thank you" and click on "Like" below my post ;-)
cinemacritic
