How to fix my nexus 4 when it turns off during update due to low battery.
Bharath Babu
3
while updating my nexus 4 suddenly turned off and after turning it on manually on it was just showing this screen. I think the battery was low so it got switched off .four coloured bubbles was just moving nothing happening other than this what to do with this please help....10808295_941311855880298_1364906576_n.jpg
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,949
5,258
113
Welcome to Android Central! If the phone truly shut off prematurely due to low battery during an update, that could be pretty serious--there's a reason why they tell you to make sure you have plenty of battery or keep the phone plugged in during the whole update process.
How long has it been on that screen? Are you able to boot into Recovery Mode and wipe the cache partition or do a factory reset? https://support.t-mobile.com/docs/DOC-5994
tooter123
201
I'm surprised it let you do an update with a low battery.
Its bedtime and If no one answers you tonight I'll try my best to help you tomorrow.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,949
5,258
113
I hope you had things synced with Google, at least--like your contacts and calendar events.
crowoverhoe
