How to get incoming calls to vibrate phone more than once?
Sep 12, 2010
17
I have looked everywhere and can't get the phone to vibrate more than once on incoming call. While it is in my pocket. If it is in my hand it vibrates more than once.
Thanks
Thanks
Do you mean the vibration pattern when receiving a call?
I am using vibration no sound. It will only vibrate 1 time then stop, if it is in my pocket.
What I meant, and granted, it may not make a difference, is have you selected another tone that rings or vibrates more than once, then turn the ring off and see if it vibrates more than once with ring pattern that rings more than once? Have you tried that?
Also, it would be helpful it you explained what you have tried.
Having the same issue, did you ever find a work around? This if intended by design as a feature, is really stupid.
Do you have "keep screen turned off" on? (prevent screen from turning on accidentally while the phone is in a dark place such as a pocket or bag)
It's in the display menu. If it's turned on, try turning it off and testing it.
trengsoba
