Welcome to Android Central! Are you getting this popup ad only when browsing, or does it also occur when you're on your homescreen or in some other app? If it's only while browsing, then it's related to the sites you're visiting -- avoid them. If it happens outside of the browser, then you installed some app that includes adware -- uninstall apps one by one until the problem goes away.
