G Grimgrak Well-known member Mar 7, 2014 182 0 0 May 2, 2015 #1 I dont see any options to do this? The only option given is to disable pairing....
Rukbat Retired Moderator Feb 12, 2012 44,530 46 48 May 3, 2015 #2 That's controlled in the driver and, in Android, the driver doesn't have any user access (like changing speed).
F fatyank Well-known member Jun 13, 2014 352 0 0 May 4, 2015 #3 I use the Samsung SMouse . Go to settings>controls then scroll down to Mouse/trackpad. There you will find pointer speed. Click on that and a slider scale will pop up. You can adjust the speed your mouse (cursor) moves across your screen Posted via Android Central App
