How to move multi window?
ShaggyKids
2,738
65
48
Is there a way to put multi window on the side of the screen that the user would like it on? Mine was on the left, somehow it wound up on the right and I would like to put it back on the left and don't see an option for positioning it. Thanks.
Very easy! Tap on multi-window tag then when it moves out , tap and hold tag and drag it to the other side! 😉👌
Sent from my Samsung Galaxy Note 3
"Size Does Matter!"
"Size Does Matter!"
Thank you! I had to use my pen to do it because my finger wasn't doing the trick but I have it moved now thank you.
kelkongko0510
