Welcome to Android Central! Are you noticing your battery draining abnormally quickly, or are you just look for tips on how to prolong your battery as much as possible? If it's draining quickly, charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
1. The main Settings>Battery screen.
2. The fullscreen battery graph screen (which may show Awake time and Cell Signal Strength).
3. The Screen category (to see total Screen On time).
4. The Cell Standby category, if present (to see Time Without Signal).
