How to set volume buttons to turn on screen?
pedromsouza
11
By default, when screen is blank, "finger print" button is used to turn it on. But I'd like to set volume button to do so instead.
Por padr?o, quando a tela est? apagada, o bot?o de impress?o digital (na tampa traseira) ? utilizado para lig?-la. Tem como substitu?-lo pelo bot?o de volume para esta fun??o?
What do you mean when you say it didn't work for you? Did you try the app? If so, what was your issue with it?
sa1234
