How to silence ringer sound during inbound call?
Trees
1,539
9
38
Is there a way to silence sound when a call is incoming? When I get calls from an unknown number I just let it ring, and if a "real" call, then it can go to voicemail.
While the call is ringing, swiping down on the notification bar to expose the sound control - does not work. The dailer screen has focus. Do I need to minimize the dailer screen to expose a home screen so that I can then change sound from on to vibrate?
MizWylie
Q&A Team
Jun 25, 2015
1,616
Re: How to silence ringer sound during inbound call
I'm assuming you want to silence a call once you look at the caller ID. I usually just volume down button and it silences the call and allows it to go to voicemail.
Posted via the Sapphire Doom Note 5
Trees
1,539
9
38
Both great suggestions. I'll try the volume down while on the go, and the face down while stationary or when a suitable flat surface is available. I forgot all about the face down option from earlier Notes.
Delirious D
776
I flip my phone upside down. I believe its a setting you might have to enable.
