How to solve this blue tint issue on my note 9 when using the flash
  • Start date Start date
A
Android Central Question
When taking pictures when the flash is on there is a horrible blue tint after the pictures are taken how to fix
Can you link us to and example unedited photo so that we can see what you are seeing?
What are your camera settings?
If you are using the manual settings, your white balance may be set to make standard (yellow) house lights look right, which would cause the light from your flash to look blue.
However, an ill-fitting phone case is the first thing I would check, as mentioned above.
Diagnostically, put a white card on the back of the phone with holes cut for the lens and flash, as small as possible to exclude all possibilty of reflection from the blue case of the phone. Take some test photos. Tell us the result.
Khalequzzaman
