- Feb 17, 2013
- 51
- 0
- 0
Hi all,
I just received my nexus 4 on Monday, 02/11/2013 and haven't used it since first day. When I turned it on on first day, it was around 90% and I turned it off after. All i did was scroll around on the nexus like the preloaded apps and options for maybe an hour max. Just yesterday on Friday, I turned it on and it was completely dead. I read somewhere that the standby time was approx 16-19 days and its only been 4 days, and i turned the device off. I was wondering if its a battery defect of some sort so I can request exchange. How can i test the battery if its normal, like for apple, i can let a movie play continuously to compare it to the data apple gave to see if its the same.
Another thing is that my nexus does have the earpiece buzz, when i put it on my ear, i hear this buzzing noise that kept beeping then there is a pause maybe half a second here and there. Even when the screen is off and even on. I was wondering if this is a big deal or is common as many people complained about it. I currently don't have a plan so i cannot test the call option if its buzzing while calling. Should i ask for exchange?
Also the update was downloaded today of 4.2.2 (currently running 4.2) and I wanted to know if I should update it, but I do want to use lte option /menu later since I am in Canada and it does work on some carrier.
And is there any other defect or problem i should check for other than these?
Thanks very much in advance!
