How to tell if Nexus 4 Battery is Fully Charged?
yukichi
55
I know there is a battery icon in white that fills up, but when its fully charged, does it say "100%" on it or anything? Or does it just show as a solid filled in white battery icon?
It will show a solid battery icon. if it is still charging it will show a thunder synbol in the battery icon.
thats how you know its charging.
or when you press power button in lock screen it will say "Charged"
Percent is in the pull down menu:
Sent from my Nexus 4
I use an app called "light flow" to control the led when charging. Surprised that's not a built in feature. I have it set to blink yellow when charging, then be steady green when fully charged.
You can set the led color for any notification as well.
yeah, i'm surprised it isnt a built in feature either. maybe google will in include in an update sometime?
marksains61
