How to turn on theme store on s6 edge?
  • Start date Start date
A
AC Question
On opening theme store, there was an option to add shortcut to the screen. I did that. Than i pressed it and there were two options. 1 turn off . 2 remove
I did turn off.
Later on long pressing the screen and thn pressing themes. My themes opens up. But i cant access the theme store option. It just doesnt open up.
Please help me out
Go to settings, then click applications, then click applications manager, scroll down until you see themes store once you enable it youll have to uninstall the update, (once u open it itll update and be ready to use)
Nehasingh12
