- Jun 27, 2012
- 439
- 0
- 16
I currently have a verizon pixel xl. Which I may not have by the time I need the answer to this question.
I will be traveling to New Mexico in June of 2019 to accompany my sons crew on a trek in Philmont scout camp. From what I read and see on coverage maps. Verizon coverage in poor at best. But t-mobile is surprisingly good. I am sure spotty but it definitely covers more area. While I don't plan in making many calls, or using the spotty service to drain the battery, I will most likely be using my phone as a gps(airplane mode) and camera(also airplane mode).
The phone or service part would be for emergencies and I did plan on surprising the boys by being able to make calls home on top of baldy(tallest peak).
So without carrying 2 phones, or switching, I figured (as long as it was the right sim card) I would get a pay as you go phone (or sim card if that is possible) and just switch to tmobile when needed.
I have never had more then one sim. My real question is just how good will it be? I know this pixel (and other phones) are swap-able, but would it work better if I did just by a burner from tmobile instead of sim swap? Thanks in advance.
