How will Marshmallow handle USB ACA's?
  • Start date Start date
A
AC Question
Marshmallow uses different USB configurations than earlier Android versions, namely a) charging only b) transfer files c) transfer photos & d) MIDI. If a user chooses b) or c) and connects using a USB ACA (Accessory Charging Adapter, as defined by USB IF) will the Android device still charge and transfer files at the same time, as the ACA is supposed to allow it to do?
it will always charge the device no matter what option you select, pretty much the same as in 5.1.1 and older.
dkang
