• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues, please let us know in this thread!
HTC 11 huge battery drain issue
  • Thread starter Android Central Question
  • Start date
A
Nearly 50 percent of battery is getting drained by the apps.Please give me solution
Rukbat
Retired Moderator
Feb 12, 2012
44,533
18
That's nearly 50% of the amount beiong used. So if your battery is at 95%, you've used 5%, and 50% of that - 2.5% - was used by apps.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
161,898
252
83
Welcome to Android Central! Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
1. The main Settings>Battery screen.
2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
3. The Screen category (to see total Screen On time).
4. The Cell Standby category, if present (to see Time Without Signal).
http://forums.androidcentral.com/ge...ide-how-post-screenshots-android-central.html. You'll have to register on this forum first. https://forums.androidcentral.com/ask-question/409154-join-android-central-community.html
You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
