HTC 1500 Battery for Ozone, I HIGHLY recommend
DougFNJ
228
33
28
I went to Verizon Store on Friday night and bought the case/holster kit which I was a little hesitant about being I didn't want to add any extra size to my Incredible, but the tradeoff was fine, not a bad setup.
Anyway, I also ordered the HTC Ozone battery for it, they didn't have them in stock so they shipped it, and arrived yesterday. I put it in and charged it at around 11AM yesterday. I bump charged it so I would get it completely topped off. I used the phone moderately, maybe 45 minutes talktime, texting, emails, and some gaming. on the stock battery it was usually dead before the end of the night, that includes having to charge in my car on my drive home.
I am thoroughly impressed, 25 hours later and I am at 55% and this is only on the first charge :D
The only complaint I had with this device was battery life, other than that it was perfect in every way. I don't know if there may had been something wrong with the stock battery or what it could had been, but if this new battery continues to hold the charge consistently like this, I will be in heaven with this phone for a looooong time to come :cool:
Their website shows out of stock now for those batteries , where I am anyway. Yay just my luck , :p
I would call a store or drop by and see, I didn't check the website before they ordered....you never know.
I think I found a use for ny $25 promo card. Probably visit my local store tomorrow.
Same. Two 1500 mah Droid Eris batteries and a wall charger for $9.99, free shipping. So far, the batteries are holding up for just as long as the OEM battery that came with the phone.
hmmm if its the same battery then why isnt the Eris listed on that amazon listing? this does sound promising, keep us posted when the rest of you get the ozone ones :D
One heads up by the way....bump charge it all the way, this should definitely maximize it BIGTIME!!!
I am looking to condition this battery, I was always told the first 2-3 charges let it drop down to zero and then charge full.
If you are unfamiliar with Bump Charging, you charge the battery with the device on until you get the green light.
When it is green, unplug the device. Turn it off, and then plug it back in. You will see the orange charge light again. It will give an additional charge for 20 minutes or so.
When you see the green light, don't turn the device on, just unplug it, then plug it in again until it's green again. Do it one or 2 more times and you should be good.
how can a 1500 do better than the 1750 seido? O.o
That's self-explanatory, but as a low-cost quick fix it's worth it. Yeah, the 1750 isn't much more expensive, but if you can get the Ozone battery cheap (my discount it was only $20) why not give it a shot? :)
If you plan to use your device heavy (tethering, rooting, surfing, Farmville) then of course the 1750 or higher would be a better choice. For regular use that the stock 1300 didn't last long enough for, the 1500 is just fine.
I'm only charging every other day, after running it down and bump charging 2 weeks ago. ;)
I am wondering if any of you have switched from this to the seidio 1750 or from the seidio to this?
I currently have the seidio and remember numerous posts about it not actually being 1750.
Just wondering which one is better.
Avatar
