Htc evo 4g hboot problem...
MvZiC MaN
16
I know its been answered before but ive tried everything...
I'm stuck on Hboot 6.17.0001
Revo says S-off already but phone says S-on and I've tried over 20 times and downloaded over 10 different ruus and such so I can restore back to stock and reroot..
Ps I bought this phone off ebay and it was already like this...can anyone help??????
SUPERSONIC EVT3 SHIP S-ON
Hboot
6.17.0001
Android Version
2.3.3
Baseband Version
2.15.00.0808
Kernal Version
2.6.35.10-g13578ee
htc-kernal@and18-2 #1
Wed Jul 20 18:06:16 cst 2011
Build Number
4.53.651.1 CL133994 release-keys
Software Number
4.53.651.1
Browser Number
webkit/533.1
PRI Version
2.15_003
PRL Version
60690
Sent from my HTC evo 4g using Tapatalk
OperationA7X
1,432
21
38
What exactly is your issue? Bootloop, downgrade, flashing a custom ROM, etc.
Sent from my HTC Vivid WCX using Android Central Forums
MvZiC MaN
16
I can't flash any roms or root it because my hboot is at 6.17.0001 which is what revolutionary puts it at after un-rooting and I believe it needs to be at 2.18xxxx..
The previous owner un-rooted it..
OperationA7X
1,432
21
38
That's why I NEVER root that way, it screws too much up. The only way to root now is to have the bootloader unlocked, flash a custom recovery, flash a ROM, then flash the SU zip.
MvZiC MaN
16
okay so after Several hours of searching everywhere online i figured it out!! i got it out of 6.17.001 and then i got S-Off and have a custom Recovery and Suer user is on and i can open the app but the app i downloaded (Root Checker) says i DO NOT have root access
benny3
Flashoholic!!
Sep 2, 2011
2,222
40
You can just flash a rooted rom. Either a custom rom or a stock rooted. So many people get confused about root,a unlocked bootloader or s-off is not root it only allows you to write to partitons that you normally wouldnt be able to, like the the recovery partiton. Root is for the software on the phone and allows you to write to and access system files, or remove files if you choose.
As far as root checker saying you dont have root, maybe the binary didnt get installed, if you have a filemanager look in system/bin and you should a su file.
Here is super user download it and flash in recovery http://db.tt/hbeqryR5
Or like i said flash a custom rom or a stock rooted
OperationA7X
1,432
21
38
Installing the SuperUser app does not give you root access. Flash the SuperUser zip file or flash a ROM that's rooted.
MvZiC MaN
16
Thanks Guys!!!!!! its now Rooted and working (Kinda) im trying to get cyanogenmod but everytime i flash it Either in Rommanager or Manually it installes perfectly but after i reboot my phone it gets to the Blue Android Cyanogen boot screen and just Loops from there!!!!
Update: It does this with ANY and EVERY custom Rom i Flash... What gives!?
benny3
Flashoholic!!
Sep 2, 2011
2,222
40
I see your s-on, you may need to flash the boot.img, You can use fastboot to do that
MvZiC MaN
16
I fixed that so far and got s-off and then got custom recovery but it just won't run any custom roms...
Rom manager doesn't work nor does manual flash but it works perfect whenever I restore it from a backup
Sent from my PC36100 using Tapatalk 2
benny3
Flashoholic!!
Sep 2, 2011
2,222
40
What roms are trying to flash and what recovery are you using?
MvZiC MaN
16
Trying to flash cyanogenmod 7 among others that I deleted already and my recovery it's clockworkmod 5.0.2.2
OperationA7X
1,432
21
38
Flash the "boot.img" that came with the ROM that you want to use through the command prompt.
MvZiC MaN
16
Worked like a charm!!!!
Thank you all for the help!!!
Now to re-download all my apps and games!!
benny3
Flashoholic!!
Sep 2, 2011
2,222
40
I wouldn't think you would need to flash the boot.img with s-off but i guess stranger things have happened
OperationA7X
1,432
21
38
S-OFF on the EVO through a not-so-good program could cause issues. Sure, it'll do the job still, but it will cause other issues. That's why I refuse to S-OFF my Vivid. And you are correct on you don't have to manually flash the "boot.img" when S-OFF.
benny3
Flashoholic!!
Sep 2, 2011
2,222
40
Hmm. I have 5 OG's a 3d and had the LTE and never had any problems. 3 of the og's had hboot 2.18 when started, i s-off'ed them without a hitch and never had to flash the boot.img.
Like i said before stranger things have happened
MvZiC MaN
16
I don't want to start an unnecessary thread...but I'm curious if someone can link me to a rooted stock ICS ROM for my evo
And maybe say what you're favorite ROM is...
Sent from my HTC Evo 4G using tapatalk
Carybaker
