HTC One Battery Problem
connorp12
15
Okay, so I got the new HTC One on the 28th of March. And I loved it, it has an incredible battery life. For a while I could go easily throughout the day on a single charge. Even one time I didn't charge for two days, which I was never able to do on previous smartphones. But, yesterday I started having a problem with my battery. This started happening almost randomly. My battery was draining much faster, and losing about 5-6 percent per hour with no use. Previously I would lose maybe less than 1 percent battery per hour without use.
I had believed to have found the problem yesterday, with Google Play services using a crazy amount of battery like 55% on my app usage under battery settings. So I did a bunch of things to try and troubleshoot the problem and ended up force stopping, clearing data, etc. This was before I went to bed and I hoped this would work. This morning I got up and battery usage was still the same, at about 5-6 percent standby, and draining quickly still. Except now it was saying under settings in my battery usage the problem was android system, which was using 70% of battery, and as time has progressed battery life has stayed bad, and Google PLay Services battery usage has increased as well. I am a little perplexed as to why this is happening, but if any of you could give me some help, that would be greatly appreciated!
Honestly, I wouldn't go based off of the usage stats in the settings. Right now I'm having no problems with battery and Google services and android system are the top two "culprits".
And this is my usage:
Sent from my HTC One_M8 using Tapatalk
You may have a rogue app sucking away your battery. Was there an app that you downloaded right before you started noticing this?
Turn off HTC sync under accounts & sync and see if that does the trick.
Sent from my HTC6525LVW using Tapatalk
Okay, thanks for the help, I still have high usage after 2 reboots. I guess it couldn't have anything to do with android system and google play servcies in my settings, but I am just basing it of that because of just random battery drain. And also having a number like 70% for android system seemed a little suspect. The only app I downloaded was Words with Friends but the problem didn't start happening until the next day and several hours later, and I have un-downloaded it. The only HTC related items I have under sync is HTC weather, which I have enabled.
I read in another thread that someone had a problem with the weather widget draining battery and they turned off auto sync for it and rebooted and they were fine. Maybe try that.
Long shot but words with friends was doing the same thing on my iphone 5 a few months back. I imagine since your playing with people it consistently connects to data to look for "updates" to the other person making a move.
Okay I have tried all of these suggestions and am still having a large battery drain. I have used my phone for nothing but texts for about the past hour and a half and battery has dropped almost 13 percent.
I would do a hard reset on the phone again and not install anything and maybe not even sign into your google account and let the phone sit there and check to see if it does the same. If it does it could be a hardware defect.
Yeah but up until yesterday the battery life has been great. Would it make sense for it to be a hardware defect or would it have been bad from when I first got the phone?
It really depends. I have had phones where they are fine for a few weeks to a month then suddenly something goes wrong or stops working. You could keep diagnosing in different ways until you find whats wrong or return it for a new phone depending where you got it.
Anytime I've experienced above normal battery drain it's always either been an app gone rogue or a sync issue. If you've ruled out an app problem, have you tried turning off syncing for all your accounts to see if the battery drain subsides? My exchange account is notorious for causing sync problems, especially with the calendar, on previous phones.
Okay I did a factory reset, and it seems to be working fine now battery wise. But, should this be reason for concern to come up again for me. I do not want to have to constantly be messing with resets etc.
Sounds like it's more than likely not a hardware issue, but a software. I guess you could install one app at a time and after each install keep an eye on the battery?
I have had issues like this after various app updates. What I do now is not reset the phone but disable the latest updated apps. The apps still exist on the phone bu no longer run. More than likely the problem will go away. Re-enable them one by one until the problem reappears. You will find the culprit. I try not to get too far behind on my updates since if this type of problem occurs, it makes it all that much more difficult to troubleshoot.
Re: HTC One Battery Problem overlayed on top of the recent "Snitching" reports
A few days ago there was this article that interested me since I am the person responsible for maintaining my g/f's M8:
The article title was "Your Android phone is a SNITCH: Wi-Fi bug makes you easy to track" >> Pasted from Your Android phone is a SNITCH: Wi-Fi bug makes you easy to track • The Register
So, I went to work familiarizing myself further with her M8. There were a few things that looked awful peculiar about the default set up of her M8.
Although she is a T-Mobile customer with their 3GB data plan, I set out to change a few advanced settings, so that we can maximize her M8 battery life, while minding the above "snitching" caution. The first thing that I did was to set her WiFi up, so that when she is in the vicinity of my WiFi connection (no SSID broadcast and MAC filtering enabled w/WPA-PSK (TKIP)/WPA2-PSK (AES) authentication) in the house, it takes precedence over using her T-Mobile data plan. Next, I set her M8, so that the WiFi-based M8 location broadcast is ONLY enabled when she is connected to the wall. There are about 4 different "IF" situations in this setup and until such time that the 'snitching' problem is resolved, it is the best compromise that I could come up with the compromise being that she only broadcasts location when NOT on battery power and most definitely WiFI is used over T-Mobile data connection as the primary preference (even for call connectivity (Outgoing/incoming)). This setup was selected not to save money on her T-Mobile data plan but in the hopes to make her M8 a bit more secure, in the interim.
I hope this makes sense for those who read this and I hope my rationalization of the mitigating issues are not totally flawed!
godef
