Huawei pro 30 how to send text to multi contacts?
  • Start date Start date
A
Android Central Question
Huawei pro 30 How do I send message to multi contacts?
I'm sorry to say this, but EMUI is a weak android skin. You can't even multiple select missed calls etc from calls list to delete. You have select them one by one for deletion or all.
In the emui file manager , you cannot multiple select files to check size either. Just a few examples.
That bad :(
kiki2025
