huffingtonpost and other flash heavy sites not working after foyo
Marine0816
45
When I log on to huffingtonpost.com the screen freezes and won't allow me to to scroll. anyone having similar problems?
I don't have a login, so I can't do that... but it works otherwise. I'm not on Sense so I probably won't have similar experiences as you.
Um, try going to settings and putting plugins to "on demand".
if i click on a link and hit back button it seems to allow clicking but it's not loading correctly and then just stops..
Try going into settings and turning "enable plugins" to "off"...
If that makes the website work, then try turning "enable plugins" to "on demand".
Even though having full flash support is great, I still Ho to the mobile versions of sites because there are less problems and the sites loss quicker. I have actually found that the mobile versions are a lot more functional.
itsnotmac
