HUGE battery issue after update
jamielov
498
Phone wont charge anymore past 94%. Ever. No matter how long it is charging. Also depletes like crazy. In the time it took to open this page and type this message, battery dropped to 89%.
Any ideas where I can look to see what it going wrong?
Get your battery replaced. It will kill the waterproofing, but will fix your battery problems more than likely
I had excessive battery use after the update. I went thru the pain of doing a factory reset. No help whatsoever. Need a fix pushed out.
I've always had great battery life on my V30. I still make it through a whole day without issue, but there's about a 5-10% more drain than before the update.
Mine actually seemed to get slightly better after the update. I was slowly losing life per day recently, and it improved a bit after the update. It definitely didn't get worse for me.
I've always had great battery life on my V30 as well. On T-Mobile and after the update, I noticed my battery life has steadily gotten worse.
You guys having battery issues: Are the battery statistics giving you any info on what is eating more power?
Not only am I having battery issues, I am also having issues with service. Even wifi. Places where I had great wifi service before, I am barely getting any now. wtf. gee, I was all excited about 9.0 but should have just left it alone.
Not really, just standby
Now that you mention it, that does seem to be marginally higher now.
My house does not have the greatest signal strength with ATT, so I usually have wifi calling turned on, which seems to help a little.
Might be a good idea to backup things and do a reset. That may help things out unless you have a hardware issue, but I doubt that since it started with the update.
CasperTGhst
