Huge Cache Data Problem
Liquidretro
158
Went to update an app in the Play store and it said my phone was out of space. This was weird, I have an SD card in, and its a 32gb phone. I have apps installed but not a ton of them. Upon further investigation I have a 20gb Cache partition. I rebooted the phone and did the clear cache and that didn't make a different.
If I clear the cache on the storage screen will it clear it from all my apps? So will I have to login again everywhere, etc? Any idea which app is causing this? 20gb is crazy, I reset my phone 8 months ago or so.
Just go into storage from settings click on the cache and select clear cache. It will clear it out of pretty much all the apps.
Yes, it will delete the cache for all your apps.
No, it won't delete any personal information
It's difficult to know which app is caching so much data. You could go one by one in your settings - apps until you find it. The usual suspects are browsers, gallery and in general any app heavy on media files.
You can take a look at this guide about cache.
http://forums.androidcentral.com/showthread.php?t=558872
[GUIDE] A bit of cache clearing
