I am a fan of the double edge screen!
smooth4lyfe
Trusted Member
Sep 16, 2012
5,534
I heard a lot of people saying its not useful, but I find it pretty awesome!
I absolutely love Edge lighting, I think its a pretty cool feature
And I do love the edge panel mostly for sports scores and to check my stocks which I use
Anyone else find the edge screen useful?
Curve is ok. But edge screen features are pretty useless for me
I have the edge screen feature set up, but don't see myself using it much. Probably just need to get used to the fact that it's there.
I'm a fan of the edges. That was the whole reason I chose the S6edge+ last year over the note (always been a note user) I wanted the curved edges and something that was different. I wish they would have stuck with the same edge profile as the edge+ tho. These edges on the note are okay but basically useless as an edge display. Most everything is just on the edge of the screen. At least on the edge+ the actual edge was readable from well, the edge when looking at it from the side. But this is still a great blend of the two devices, note and edge+.
For a normal screen, it's fine. For edge purposes, especially the night edge clock, not so useful.
So, if you are really wanting a phone to take full advantage of the edge features, get the S7 Edge, not the Note7.
I love it but I'm a previous a note Edge users. I actually want more of an edge
What's the difference between the S7 Edge and Note 7 edge screen? I thought it was the same
mitziej
