I have a Samsung Mini S3, what causes the bluetooth connection to be intermittent with headsets?
  • Start date Start date
A
AC Question
I have a samsung mini s3, what causes the blutooth connection to be intermitent with headsets
Bluetooth connection just started this with any headset or earbuds
Re: I have a samsung mini s3, what causes the blutooth connection to be intermitent with headsets
Welcome to Android Central! How many different headsets have you tried? Make sure the headsets are fully charged, since a low battery can lead to intermittent dropouts.
If you're on wi-fi as well, see if the dropouts still occur with wi-fi off. 2.4 GHz wi-fi channels can theoretically interfere with Bluetooth (which is also 2.4 GHz), so if the dropouts go away when you turn off wi-fi, then you might have to use 5 GHz (if available on your router), or go into the router settings and change the wi-fi channel it's using.
Richie Q
