I i softbrick my phone by installing x posed frame work what should i do?
Shon Ratul
4
If want to install x posed but it shows that it can cause soft brick. So if it soft brick my phone can uninstall x posed will fix the problem?
It depends on the phone, the version of Android and the recovery you use. If you can flash a zip file, there's a removal tool. But if you're not sure what you're doing, you shouldn't be installing XPosed. Some of the modules will allow you to brick your phone too.
