I need help deciding!!!
jlmans79
11
I'm definitely getting the S3 today, but should I get the 16GB or 32?? right now I have the HTC Desire and always running out of space and can't download the apps that I want...
please help me decide if the 16 will be enough or 32 be to much
thanks
Get the 32 if they have it you can never have to much memory.
Sent from my DROID RAZR using Android Central Forums
Reactions: jlmans79
You know you can add an SD card if you run out of space right? It is definitely not worth $50 for 16gb more, when a 32 GB SD card can be bought for $20
16 should be plenty, you can always add an sd card later up to 32gb
Sent from my SCH-R530U using Xparent Blue Tapatalk 2
Don't the apps run on the ram instead of the memory storage in any case the S3 has two gigs of ram so that is a lot.
The cards r only for music n pics, and to speed update internet browsing. Unless ur rooted u cant put apps on the cards.
Sent from my SCH-R530U using Android Central Forums
Not much chance of running out of memory. I have downloaded over 200 apps n haven't even used 4gb. I do have a 16 gb card installed with about 750 pics n videos n haven't put a dent in the available space on it. Hope u are enjoying ur new phone.
Sent from my A100 using Android Central Forums
ksothpaw9
