I need help flashing my Xpreria X to enable the fingerprint sensor please. How do I do it?
Dconn1975
Banned
Aug 19, 2016
2,529
So I just bought a new Xperia X model after buying an X Performance that was supposedly like new in box but it had a bad screen. I sent it back and now I've purchased the Xpreria X. I need help from someone to guide me through the steps of flashing the European firmware to my phone to enable the fingerprint sensor. Does anyone mind helping or stepping me through the process along with sending me the appropriate links? I would greatly appreciate your time and help. I really want to be able to use the fingerprint sensor of course but I can't figure out how to fully do it. Any help is much appreciated. Thank you.
By the way I ordered my Xpreria X from B &H and they have good deals on both the X and X Performance right now. I really wished I could have afforded the X Performance but the X is definitely a good solid device and there isn't that much difference between the two. I do like the X Performance is water proof. And I really wanted that 820 processor. It really bites because I had it but only for the guy to try to hose me with a defective screen on the device so I had no choice but to run with the Xpreria X brand new instead as the X Performance don't come up used very often like I found the one that was bad or defective. Now I've just got to figure out how to enable my fingerprint sensor and I'll be set to go. I had ordered about $75 dollar worth of accessories for the X Performance so I assume they will work with the X model or I hope they do. Actually since they are so close in build I ended up ordering a combination of X and X Performance accessories so I hope to be good to go. I'm really looking forward to the Red sleeve which I might have to send it back and exchange it for the X model as they told me there is a 2mm difference in size so the one I ordered was for the X Performance so it may fit a little big on the X but I'm hoping it'll still fit good enough to keep and not have to exchange. Here is a pic of the sleeve I've got on the way.
Anyone out there who can help me or guide me through the process at all? Please any help would more than greatly appreciated.
04ijordan
